Posted by old on February 07, 2011 at 11:09:54 from (4.245.13.157):
In Reply to: OT: Heat posted by willie1 on February 07, 2011 at 07:32:50:
I heat mine once in a while with a custom built wood stove. Uses an old boiler tank for the fire box and is about 4 foot long so it can take a long piece of wood. Has the door from an old Ashley stove for the door. It has a 2nd tank like what the double barrel set up has but that is an old water heater tank. The pipe going out the roof is well casein pipe and has been hanging in my shop for about 20 years. It has seen at least 4 different stoves but still the same pipe
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
