Re: Website back up
Posted by rustyfarmall on February 05, 2011 at 14:06:30 from (209.152.78.140):
In Reply to: Website back up posted by James Williams on February 05, 2011 at 11:31:31:
Kelly, I'm certainly not an expert, won't even pretend to be, but I built my website using MS word. Everything you need is right there.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
