Posted by rustyfarmall on February 04, 2011 at 10:24:52 from (209.152.78.140):
In Reply to: Carb solenoid posted by DeltaRed on February 04, 2011 at 08:46:20:
Several folks HAVE removed them and replaced with the adjustable style found on the Farmall letter and early number series. Depending on how you use your tractor, you may get away with doing that. It IS nearly impossible to outsmart the engineers who designed and tested it though.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
