Posted by sflem849 on January 31, 2011 at 07:53:53 from (69.197.84.192):
In Reply to: tractor splitting stand posted by John826diesel on January 20, 2011 at 15:28:37:
I have my MD apart right now and it is a little scary how much the engine sags. All the people I talk to say that is the way to do it. I took the big bolts that bolt the halves together and put them through the rear support plate to help take the stress off the front of the motor. I am just not sure how everything will go back together with the pieces at different angles. Give me another month and I should have your answer!
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
