Re: farmall M gas tank mounting
Posted by Janicholson on January 29, 2011 at 08:15:26 from (67.72.98.45):
In Reply to: farmall M gas tank mounting posted by mainamana on January 29, 2011 at 07:36:18:
An isolator (Synthetic rubber/cloth) pad buffers the tank at both ends from direct contact with the supports. Studs through fairly large holes are the fasteners. there is a washer-spring-washer-nut combination on each stud to compress the spring. This allows the tank to expand and contract at a different rate than the tractor under it without being stressed. It also allows easy alignment and assembly. There is also a strip of buffer between the tank and the hood for the same reason. The parts diagrams on line at caseih.com show the assembly clearly. Jim
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
