Re: Cub head bolt sealant
Posted by gene on January 28, 2011 at 17:05:13 from (66.43.40.73):
In Reply to: Cub head bolt sealant posted by IanC on January 28, 2011 at 06:17:27:
You need a sealant of some type on the head bolt threads. Permatex would work just fine. I use Copperkote because I use it on the head gasket.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
