Posted by F-Dean on January 21, 2011 at 05:08:41 from (75.203.250.4):
In Reply to: Re: BACKFIREING posted by MisterT on January 20, 2011 at 11:06:21:
Check that you have the firing order going in the correct rotation -- I believe it should be clockwise as seen from the driver's seat. Take the distributor cap off and turn it over to double-check.
An engine will run with a lot of back-firing if you have the wrong rotation -- two cyclinders will be firing at the right time.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
