Posted by Calif. Farmall on January 20, 2011 at 15:06:17 from (76.220.192.215):
In Reply to: BACKFIREING posted by JEFF NC on January 20, 2011 at 10:27:48:
HI- sounds lean if it will start and run, if it's lean it will pop through the carb , too rich it will pop out the exhaust pipe when throttling down. Try to adjust the main load screw out 1/8-1/4 turn at a time and even the idle mixture screw a bit to the right to add more fuel. One way to check the mixture is goose the throttle quick from idle to full and it should rev up quick with out coughing back through the carb. If timing and ignition system is good and you can't git rid of the cough you may have a small passage way, air bleed ect. in the carb restricted and need more work. Write back if you still have problems and I would be happy to help, tractor carburetors are my specialty - Dan.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
