Posted by old on January 20, 2011 at 11:05:56 from (4.245.13.148):
In Reply to: BACKFIREING posted by JEFF NC on January 20, 2011 at 10:27:48:
A back fire like that a lot of times is caused by the engine running way to lean. #1 check and clean the air cleaner and make sure it has good oil in it etc. #2 open up the main jet a little at a time to see if that helps. One way to double check this is to coke it some and if when you choke it some it stops you know 100% sure it is running lean
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
