Posted by MN Mike on January 18, 2011 at 05:07:47 from (67.96.215.67):
In Reply to: Frozen Battery posted by Orange on January 17, 2011 at 15:16:49:
after you buy a new battery, consider picking up a battery maintainer as well (float charger). I keep one on my 340 all winter long in a non-heated barn. keeps the battery charged up on a trickle charge and shuts itself off once the battery is all the way up. never have a frozen battery again and know you have all the amps the battery cover says when you hit the starter.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
