Re: Frozen Battery
Posted by Bob on January 17, 2011 at 15:45:36 from (64.255.159.192):
In Reply to: Re: Frozen Battery posted by snoop-nc on January 17, 2011 at 15:30:39:
The REST of the story is that often a battery that has been frozen will not be much good after being thawed out and charged.
I'm GUESSING the plates or separators or the "walls" between the cells get torn up/cracked/damaged.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
