Posted by Armand Tatro on January 01, 2011 at 16:33:08 from (71.239.9.235):
In Reply to: GAS CAP posted by 460anger on January 01, 2011 at 15:49:32:
The float on that gas cap gauage is what makes those gauges so useless, worthless, and agravating. If you look closely at the cork floak you will see that it is strating to break apart. As the fuel gets low the floating pieces of cork will end up blocking the tank outlet and shuting off fuel flow andcausing tractor to stall. That gauage is best hanging on a nail in the shop where it can no harm, angravation. And stress. Armand
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
