Posted by Bob M on December 26, 2010 at 13:19:07 from (67.240.171.41):
In Reply to: 1951 Cub,.. skipping posted by kennebunksawmill on December 26, 2010 at 12:52:20:
Did the engine run OK after warming up 5 minutes? If so the problem could be as simple as stale gas in the carb bowl.
The "reformulated" gas we're forced to buy now contains 10%+ ethanol. It works OK in fuel injected engines. But it deteriorates (become less volatile and absorbs water) quickly - even when treated with Stabil, etc. This causes starting/running problems in carbureted engines - especially if an engine sits idle for several weeks.
Solution is to keep fresh gas in the tank. Also when finished with the tractor shut off the fuel at the sediment bowl and let the engine run until it quits before shutting of the ignition This way no fuel is left in the carb bowl. Now you next time start it, the carb bowl will be filled with fresher fuel direct from the tank.
Another possibility - if the humidity was high when it gave you trouble - is carburetor icing. Solution is to thoroughly warm the engine before putting it to work. Also covering the radiator then shielding between the radiator and carburetor so warm air from the radiator flows back over the carb helps.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
