The secret is to limit primary ignition current to the range of 3.5 to a little over 4 Amps, (points CLOSED engine stopped, ignition switch "on") to prevent overworking the points so they quickly burn and/or overheating the coil.
The CORRECT combination of the original 6-Volt coil AND external ballast resistor with the proper value will achieve this and even allow for a "starting bypass circuit" to give full voltage to the coil for cranking, if desired.
OR, a "true" 12 Volt coil that needs NO ballast resistor will work, instead. (NAPA IC14SB, for example.)
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
