Letting it run on gasoline for 2 minutes, then switching should have less than 15 seconds of missing on diesel. If it is switched over too early it will show some white smoke. If it is rich on the gas operation, it will be gray white looking diesel misfiring. If it takes 30 seconds to two minutes to clear up, it could have a poor injector pattern, or poor compression. A compression test and leak down test can be made on the gasoline operation to assess differences between cylinders. Finding the cylinder that leaks can be easily determined with a hand held infrared digital meter. Good luck. Jim
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
