You may have a voltage drop when you pull the starter in.Check the battery voltage at the posts before you attempt to start and then test at the posts when the starter is engaged. If your battery cables are good there shouldn't have more than 1-2 volt drop when the starter is engaged. If the connections are corroded or the cable has interior corrosion you may be dropping the voltage at the coil too much to get a good spark when the starter is engaged Clean all your battery connections. Another suggestion is check the timing you may have the spark a few degrees too advanced to allow it to start with the starter
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
