Chris, I have seen quite a few C113's cracked in that area, and to the same extent. I have also see successful re-use of those cracked blocks and I have seen failures.
So, if you decide to give it a try, here are things to consider. These engines are thermo siphon. No pressure from the cooling system. These engines are low compression and low RPM. I believe it was Gene's comment that that area is low stress, and I agree. Also, these are sleeved engines, another plus.
The absolute best route is a good used block. However, if that doesn't work out, you can certainly try to use this one. The only potential waste of $$$ is the head gasket and your time.
Interesting thought. I have taken heads off of C113 engines to do valve jobs and found the block cracked in the same area as yours. Aside from needing a valve job, the engines ran fine, ie. no oil in coolant, and no coolant in oil. If I hadn't pulled the head, I would never have know it was cracked. Long story short: you have to decide, because "your mileage may vary"! :wink:
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
