Answer is "it depends". Best case scenario is a battery charge (free) and perhaps a new voltage regulator ($40).
More likely however you will also need a new 6 volt battery, voltage regulator and new heavier, battery cables - about $150 or so.
And if the generator is bad, a rebuild will run another $100 - $125.
Incidentally I would replace the existing 8 volt battery with a new 6 volt regardless. Over the long haul it will cost less to find/fix the problem that caused the previous owner to install an 8 volt battery in the first place!
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
