I wouldn't think the mag would have anything to do with a battery drain since a mag isn't powered by the battery. Instead I would probably go for the voltage regulator. Connect a test light in series between a battery cable and the battery post. If the test light lights up, then you have a drain. If not, then you probably have a battery with an internal drain. If you have a lit test light, then start disconnecting wires, one at a time. When you disconnect the circuit with the drain the light will go out. I would probably start with the wires to the VR. The VR contacts can stick, causing a drain. Hope this helps.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
