Posted by LarryT on November 24, 2010 at 22:22:36 from (68.35.57.27):
In Reply to: W400 liners posted by Rod in MN on November 24, 2010 at 20:13:25:
If its stock and hasn't been bored over like the last two I have done. IT appeared that the block had been damaged and someone had over sized it, or they wanted over sized sleeves and pistons in them but both were way over by .060 and the stock sleeves just fell in and rattled around. Had to measure them all out and ordered .060 over from the parts house. Now I have 3 different sizes of pucks as you call them. LOL what a mess we sometimes run into. Good luck all.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
