Posted by LarryT on November 24, 2010 at 21:15:03 from (68.35.57.27):
In Reply to: W400 liners posted by Rod in MN on November 24, 2010 at 20:13:25:
What I have done is measure the ID and then the OD down at the bottom and then you can have a centering ridge placed in it and it makes it so much easier to pull those out without slipping out of place and getting against the block bore.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
