Posted by Bob on November 21, 2010 at 14:50:44 from (69.178.228.68):
In Reply to: Discharging 300 posted by Shawn MN on November 21, 2010 at 13:25:18:
Polarize the generator by momentarily jumpering the "BATT" and "ARM" terminals at the voltage regulator with the engine "OFF".
If it still doesn't charge "full-field" it by jumpering the "F" terminal to ground at the generator. If it now charges, most likely you have a VR problem. If the ammeter STILL doesn't show charge, check the voltage at the "A" terminal at the generator to see if the generator is putting out any voltage and the trouble could be a bad VR cutout relay. If no significant voltage at the generator's "A" terminal with it "full-fielded", most likely there's an internal generator problem, check the brushes first.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
