More thal likely it is a pinhole in the intake pipe from the reservoir to the pump (larger diameter suction pipe or hose) If it is leaking air, it might not leak fluid. Orings where they attach to either end can be bad, and the hose can have broken layers that suck air and flap shut to prevent leaks from showing up. Careful use of a squirt oil can filled with hytran, and good light, with it running can find spots sucking in air. If there are wet spots on the suction hose, clean them and use some black vinyl tape to temporarily stop the suction leak. If it works, replace the hose/line. Jim
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
