Re: generator, regulator or cut out
Posted by Janicholson on November 12, 2010 at 20:35:11 from (67.72.98.45):
In Reply to: Re: generator, regulator or cut out posted by Dave Cook on November 12, 2010 at 16:27:37:
The Voltage regulator adjusts the generator output to limit the charge rate according to the needs of the battery, and lights/electrical loads. It maintains a 7 to 7.2 volt charge rate and will top off the battery, and not over charge it. It also contains a cutout relay that is the same as a stand alone cutout relay.
A generator in operation has an almost direct link to the battery negative and to ground on its frame.
As long as it generates more volts than the battery it is happy. If the idle is low, or lights are on at low speeds, or the engine is off, the generator would be a direct connection to ground and thus in short order it would overheat and burn up. It would draw as much or more than it can produce. It is thus necessary to disconnect it as soon as its voltage is less than the bat voltage. The cutout does this, preventing excess discharge.
The voltage regulator sees gen output, and varies the F terminal path to ground. From full ground max output, to just keeping up with a light demand, it senses the needed voltage, and grounds the F terminal appropriately. This grounding (on this A type system) is the only way the field is energized, it is fed voltage inside from the third brush, or from the Arm terminal to get its power source. Jim
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
