Posted by Owen Aaland on November 08, 2010 at 21:34:32 from (65.161.86.17):
In Reply to: 350 LP transmission posted by tleake on November 08, 2010 at 11:41:14:
Is the noise there with the clutch released in neutral? If it is you probably broke a tooth on the constant mesh gear in the front of the transmission. You can remove the belt pulley drive assembly or cover plate to see inside the transmission.
If the noise is there only while moving the problem most likely will be in the final drives or ring and pinion gears. Don't overlook the possibility of of a loose wheel causing noise.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
