Check to make sure you're getting battery voltage to your coil if you have a distributor. With the points open and your ignition switch in the on position you should have battery voltage on both small terminals on the coil. If there's no voltage here you need to check your ignition switch for voltage. Run a separate wire from your battery to the coil then see if the tractor will start. Hal
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
