I'm guessing that new tires in a size to fit that B will run in the $300 to $400 range each. Tires with big cracks in them definitely ARE a concern, and if those cracks are bad enough, the price of the tractor does need to be discounted. I've got an H that had rear tires that looked even better than what's on that B, except for the cracks in the tread and sidewalls, but I wasn't too worried about it. Went to the shed one day early this spring and found the H sitting all lop-sided because one of the cracks in the sidewall had decided to open up and let the tube come through. I took that tire off the rim, and found that crack had split apart to the point that I could push my fist and arm right through. 2 new Titans and 2 new tubes set me back almost $1,000.00.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
