I"m at a loss for all I disconnected was the remote FastHitch lines and the rods from the TouchControl levers. The hydro unit, pump, and metal tubes to/from pump to hydro unit remained intact during all this.
I"ll try it again tonight and hope it"s air stuck in the system, but anything else I can try or check?
Thanks[/quote]
You say you left them intact, but did you drain the fluid from the reservoir? If you did, the pump is probably not primed. If you did not drain it, you will need to check for system pressure like El Toro said.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
