Posted by old on October 13, 2010 at 19:07:13 from (4.245.10.173):
In Reply to: c won't turn over posted by dusty dog on October 13, 2010 at 16:47:14:
First off blow the cylinders out with air if you can. Then pour some ATF in the cylinders and put the plugs in and let it sit a day or 2. Then pull the plugs and I'll bet it will turn over just fine. If your area has been like my area this year it has been very humid and that is enough to cause tat problem Had that on an A engine just today and it has ATF in it right now
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
