Posted by glennster on October 02, 2010 at 19:13:05 from (99.90.9.153):
In Reply to: super h deck posted by ridetoslide on October 02, 2010 at 11:14:07:
if its just the bolts that hold the seat on, i do not think they go all the way through the cover. on my m and super m, the bolt holes bottom out without getting into the trans/differential case. you could drill and use heli-coils or thread serts and not have to remove the deck. also, if you see a tool truck going down the road, ie matco-mac-snap-on or cornwell, flag the guy over and pick up a set of left hand drill bits and extractors. the set has about 5 bits and 5 extractors for around 60 dollars or so. use the left hand bits when you drill, often when they snag, they will spin the bolt right out.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
