Posted by Janicholson on September 25, 2010 at 15:24:04 from (67.72.98.45):
In Reply to: Farmall 130 Electrical posted by BohemianJon on September 25, 2010 at 05:39:31:
The wiring included below will give you a diagram for an A,B, or C. YOu do need to determine if it is 12 volt, but it is probably 6 positive ground as you indicate. The voltage will not make a difference, the only difference in the diagrams will be the inclusion of a starter relay (if yours has one) but the gen will wire the same. First is from the a terminal on the gen to the voltage reg Arm terminal on regulator (10ga wire), then from the F terminal on the gen to the Fld terminal on the reg (12ga wire), then from the gen bat term to the amp gauge load side (10ga), then to the starter switch (10ga). Vr and gen need perfect metal grounds to work.
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli
... [Read Article]
Latest Ad:
1945 Farmall wide body gas with pto and front plow. Runs good but needs new points.
[More Ads]
