Posted by toolz on September 21, 2010 at 19:34:46 from (206.221.147.30):
In Reply to: 414 into a 666 posted by Blackstack on September 20, 2010 at 09:39:35:
Haven't done it, but am starting on a 560 soon, so I'll tell you what I think I know. Any rear engine plate from a common 400 series tractor engine will bolt to your clutch housing, but the flywheel will be too far forward to engage the starter (at least that's the case on a 560). A spacer will have to be made to move the flywheel rearward enough to work. Don't know about the ring gear diameter on the 666, but the flywheel has to be turned down to fit a 560 ring gear for it to work on my tractor, might have to do the same on yours. The front engine plate will bolt inside the frame rails, but has to be machined narrower to fit between the 560 rails, possibly on yours, too. The engine will probably be too long for the fan to fit behind the radiator, so the rails might have to be lengthened a little, or a spacer machined to fit between the rear of the rails and the engine plate, which is what I might do. In my case, the fuel tank has to be modified to clear the valve cover. The rest involves linkage and plumbing, which shouldn't be a big deal. It's definately not a bolt-in deal, but it can and has been done. These are the things I've read or been told, I may be wrong, and will find out how wrong as I do the swap this fall/winter. I'll be an expert by spring...
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
