To add 1/8" of bore, the sleeves are thinner therefore no block machining should be needed. The outside diameter of the new sleeves will be the same as your old ones. Take the old sleeves out and measure the inside diameter of the block at the bottom of the sleeve where the "O" Ring seal is. There was more than one diameter used there, depending on the vintage of the block. Once you know what you have, you can get exactly the sleeves you need.
I had a machinist make my "Puck".
There shouldn't be any interference issues going to high compression pistons unless someone has shaved a lot off the head previously. I had that problem on one head and solved it with a just a little bit of machining on the head. Turned out to be not a real big problem.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
