Posted by redih on September 11, 2010 at 10:19:59 from (208.91.177.142):
In Reply to: New Owner of 1966 140 posted by stromboli1025 on September 10, 2010 at 20:17:35:
since you replaced points and condenser, making sure that the condenser wire did not turn and ground out as you tightened the nut on point and condenser. did you set point gap on high side of distb. cam? if you turn on ign.switch test lite should lite on + side of coil.by opening points test lite should lite on - side of coil. NAPA makes a set of ign. wires that are still wire. if you left wires on dist.cap while you were doing this good. if not you will have put compression stroke on tdc and see where rotor is pointed and put wires in right. good luck
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
