The important question is (like sflem) asked...how suped up of a class do you intend to pull in? Pulling a straight H in Division 1 NATPA pulls will drive you nuts...kinda like pulling a stock JD B...not much you can do within the rules that will make you competitive in the 4500 or 5000 lb classes if you have good stout weighted up Super Cs and Super 66s pulling...after that you"re into JD As and IH Super Hs. One thing I have seen work is if you can find a donor H that had the low low low creeper 1st gear..."bout the only time I"ve seen an H beat the Super Cs. You can rejet the carb a tad, but then you"ll be going through plugs when you"re not pulling, You can play with the governor spring to some extent. Now if you are gonna jump up to division 3 or beyond, the sky"s the limit...well actually your wallet is the limit.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
