I cannot see your SC. Many have a mechanical switch that is mounted on the starter with 2 screws. THe mounting position of the switch is away from the contact (under the sw) filing out the holes will allow the switch to move toward the contact, allowing it to make contact. If your tractor has a different type switch, let us know. (or use a picture). A direct hump from battery to starter stud, and battery to ground, will bypass all switches and determine if the starter is working. Make sure it is in neutral. Jim
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
