Thanks for all the input! I tested the generator by only connecting to the battery, the unit would turn. Also shorted terminal "F" to ground and checked the voltage on terminal "A" with the tactor running and got about 15 volts. All looked good until I took the generator apart, the wire that goes from one of the brushes to terminal "A" had some of the coating off and touching the case. Fixed the wire and the tractor is charging correct with an output of 6.9 volts on a charged battery. Thanks for the excellent info!
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
