Posted by Nebraska Kirk on September 01, 2010 at 16:59:05 from (207.91.4.159):
In Reply to: MW live pto clutch posted by dougct on September 01, 2010 at 04:11:00:
You will need to buy these three parts to use in addition to the parts you already have.
Pinion gear
brake drum
brake cover
You can use the brake band and linkage that are on the tractor, just remove them from the M&W clutch cover. Once you have removed the clutch, remove the hollow M&W pinion gear from the pinion gear carrier, remove the bearings and reused them on the solid pinion gear that you put back in the pinion gear carrier.
NOTE: You don't have to remove the tranny cover to pull the clutch, it can be done by removing the PTO and going in through the hole. The main thing to remember is that the left axle MUST be pulled out of the left bull gear and the bull gear pulled back away from the pinion gear carrier, only then can the pinion gear and carrier be pulled out of the side of the tractor. If you don't move the bull gear back before trying to pull the pinion gear carrier out, you will break the carrier.
PS I deal in complete M&W clutches and parts, if you want to sell the clutch, let me know krinne@windstream.net
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
