The tools you mentioned are what Bates used. Their job on the cross pieces on the grill was pretty good. I used some body filler in places. They did nothing else except put some primer on it that I had to remove, then fill the dents in the rest of the grill and get rid of the rust pits. They did do a good job fitting the grill screen. I saved about $200, but added $300 worth of labor, if I didn't do it myself.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
