Posted by pete 23 on August 11, 2010 at 15:01:56 from (173.87.8.216):
In Reply to: M magneto trouble posted by William Ransom on August 11, 2010 at 14:18:39:
If you have good spark like you say when coming direct off coil, your problem is in either cap, rotor, wires or internal timing of the rotor. The reduction gear has an R and L and the R should be lined up with the notched tooth on drive gear. Make sure point gap is .013 as more or less will effect lag timing.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
