It sounds like you're trying to remove the vertical shaft. The large gear is a tapered spline fit on the end of the shaft and that is what is holding the shaft in place. You will not damage the thrust bearing by hammering on the end of the shaft. It is accepted practice to put the nut on the shaft and hit it hard. I use a wood block on the nut as my aim with a 5-pound sledge isn't what it used to be. When the shaft comes loose from the gear, the nut will keep the shaft and bearing assembly from falling on your foot.
mkirsh has explained how to remove the steering shaft which should be done first.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
