In Reply to: Farmall 560 Weight posted by MartinD on July 28, 2010 at 07:58:25:
Just weighed mine at local grainery and with narrow front end, no fluid in tires, double wheel weights on rear tires, front wheel weights, and new 16/9/38 tires on rear it came in at 7100lbs, no fast hitch or belt pulley on this one.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
