On my 100 spreader, I ground the ends off the rivets and then used a punch to drive them out. With a good 4 inch angle grinder, it only takes a few seconds to grind off each rivet so it can be driven out. As to the rotted floor and the rivets there, I used an angle grinder with a thin cutting wheel to cut them and then drive out. A reciprocating saw would work too I think. When you go to cut new boards for the floor, be aware that the body of the spreader is wider at the rear by about 1 inch and the edge boards need to be tapered to compensate for that. The body is wider at the rear so the manure can be easily pushed to the rear by the drag chains. I replaced the floor and the metal sides in my 100 spreader.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
