Posted by gene on July 20, 2010 at 16:03:16 from (66.43.40.73):
In Reply to: Cub oil leak posted by Mike in Ohio on July 19, 2010 at 21:00:47:
Not the oil pump leaking. If it were it would lose it's prime.
Rear main engine seal or transmission front seal. Both oil leaks show up at the same location.
If you haven't done so, drain the transmission/differential and refill. Transmission has a tendency to accumulate water bringing the oil level up to and on the seal.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
