Posted by Janicholson on July 18, 2010 at 21:24:42 from (67.72.98.45):
In Reply to: M tubeless tires? posted by MeanGene1 on July 18, 2010 at 20:01:34:
Tubeless tire rims are different than conventional tube rims. The bead on a tubeless tire is designed to be seated on a tapered section of rim such that when it is against the rim wall it is also pressing hard against its inner diameter om the rim. This is not true of conventional tube type rims, they are basically flat at the bead till the flange. THe tubeless tire engineering specification and rim is very different. You could put a tube in the tire, (being sure that it is the correct size) and possibly have that work. But it will not work as a tubeless on a standard rim, even with a sealing goo, it will not seat correctly, and will deflate radically. Jim
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
