Posted by The tractor vet on July 16, 2010 at 06:15:43 from (76.212.231.173):
In Reply to: 574 clutch ?? posted by TGIN on July 16, 2010 at 04:42:45:
Well your not going to like this BUT it may vary well be that the thrust bearing or as some call it the main thrust bearing may have started to spin. When you push the clutch pedal down you are forcing the crankshaft forward against the thrust bearing and everything works like it is suppose to . Then something happens and it runs dry for a split second or something causes the tri metal to flake off or grab and it spins maybe a bunch maybe just enough to cause a bind and labor the engine just a wee bit .or lock it up tight as a drum. I am not sayen that this is the problem this is the worse case that it could be and if the engine was laboren and does this when you push the clutch down this is where i would be looking and FAST .
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
