Re: Farmall H swinging drawbar and U shaped drawbar questio
Posted by mkirsch on July 09, 2010 at 06:31:45 from (64.80.108.55):
In Reply to: Farmall H swinging drawbar and U shaped drawbar question?? posted by John in CT on July 08, 2010 at 15:26:34:
The main reason for bent drawbars is abuse, overloading, etc.
The horseshoe can get worn thin in the middle where the swinging drawbar roller spends 95% of its time, after 60-70 years of normal use, too.
I wouldn't worry about reinforcing anything unless you plan on intentionally overloading the drawbar.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
