If your gonna REALLY load it(probablly too much for an H) then doubling up the drawbars would work. My 650D had the u-shaped drawbar reinforced that way with one u-shaped drawbar welded right on top of another. Got it that way, they used to pull earthmovers with it... But then, around here, I've never seen anything hitched to the swinging drawbar on an old IH- never even seen a swinging drawbar on one..all there ever was on them was the u-shaped drawbar....and I've seen a few of them bent and twisted in iron piles...
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
