3 pt will not go down: Maybe the unload valve is stuck. Check with engine running, raise the hitch and at same time pull the remote lever. If the hitch raises, you have dirt in the unload valve. This valve is under the seat and you remove the large plug for access. One trick, loosen the large plug, unload valve, 2 turns and start the engine, the hitch should raise if the valve is stuck. It has a small hole in the valve and just blow the dirt out with air. Replace the O-rings with new ones. OR There is a cover on the right side, in front of the rock-shaft. Remove and check if the spool valve moves with the position lever. Make sure the draft lever is down. It has a long spring, with a rod, may be that spring is not unhook. Bernard le mécano Québec Canada
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
