Posted by glennster on June 30, 2010 at 17:31:47 from (99.90.9.153):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
if its 12v neg ground, the - wire should be connected to the ignition points. if its still 6v + ground, the + side should be connected to the points. even if reversed, it should still fire. get a test light and hook one end to the hot side of the battery, with the ignition points open, remove the wire from the coil that goes to the points and put the test light on the wire. if the lamp lights, the points are grounding out. check the insluator where the wire connects to the side of the distributor to see if the insulation is bad, or if something is touching to ground out the points.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
